Questions about facets
matish
Re: Questions about facets
Post by matish » 26 Nov 2025, 14:04
I am doing this in a separate Laravel project. Aimeos installation is not part of it. I am accessing Aimeos only over the API and customer sees this as a single request. Actual API requests are hidden from the customer.
I am assuming that PHP is making those requests one after another.
One solution, that I am thinking about: is to allow comma separated aggregations.
For example:
/jsonapi/product?
include=attribute,media,price,product,product/property,text,catalog,supplier,stock,property,product/property/type,attribute/type
&filter[f_oneid][vendor][0]=15
&filter[f_oneid][vendor][1]=16
&aggregate=index.attribute.id,index.catalog.id,price:min,price:max
But that one requires code changes on the Aimeos end.
matish
Post by matish » 26 Nov 2025, 17:18
Ok, I have played around with prices a bit.
I would say, that min price works, max price works, but range filter does not work.
Raw URL:
https://aimeos.priit.yt.lan/jsonapi/product?include=attribute%2Cmedia%2Cprice%2Cproduct%2Cproduct%2Fproperty%2Ctext%2Ccatalog%2Csupplier%2Cstock%2Cproperty%2Cproduct%2Fproperty%2Ftype%2Cattribute%2Ftype&page%5Blimit%5D=6&page%5Boffset%5D=0&filter%5B%26%26%5D%5B0%5D%5B%3E%5D%5Bindex.price%3Avalue%28%22EUR%22%29%5D=1332&filter%5B%26%26%5D%5B0%5D%5B%3C%5D%5Bindex.price%3Avalue%28%22EUR%22%29%5D=1716
Decoded
/jsonapi/product?include=attribute,media,price,product,product/property,text,catalog,supplier,stock,property,product/property/type,attribute/type
&page[limit]=6
&page[offset]=0
&filter[&&][0][>][index.price:value("EUR")]=1332
&filter[&&][0][<][index.price:value("EUR")]=1716
It should return products that are priced between 1332 and 1716 EUR, but it returns products that are visible on the picture:
Am I doing something wrong or is this a bug?
When I was working with aggregations today I discovered that when calculating price:min and price:max, then I should not pass the price filter for it. So it is good to keep those requests separate. But still, if comma separated aggregation would be possible, then I could reduce the number of requests needed.
Post by aimeos » 28 Nov 2025, 11:21
matish wrote: 26 Nov 2025, 14:04 I am doing this in a separate Laravel project. Aimeos installation is not part of it. I am accessing Aimeos only over the API and customer sees this as a single request. Actual API requests are hidden from the customer.
Your approach combines the worst of both worlds because you need several requests to get the data and you have to perform them all for every single request. If you don't execute the requests in parallel, you get an incredible slow frontend with lots of data transfered between the Aimeos API and your frontend server. We strongly recommend to take a different approach to avoid a bad user experience and a disappointed client.
matish wrote: 26 Nov 2025, 14:04 One solution, that I am thinking about: is to allow comma separated aggregations.
For example:
/jsonapi/product?
Combining aggregations like this is not possible because the different data would be merged into a single array where you might not know which is included for what reason.
Post by aimeos » 28 Nov 2025, 11:24
matish wrote: 26 Nov 2025, 17:18
&page[limit]=6
&page[offset]=0
The filter part has wrong indexes and must be:
&filter[&&][1][<][index.price:value("EUR")]=1716
matish
Post by matish » 28 Nov 2025, 15:06
Thanks for the correction. I got it working now. Documentation is a big vague on the indexing. It is just saying '[]' but no specific numbers inside.
Maybe you are right.
Well, I am not doing it for the client. I am doing it for myself, to see if there is a way to achieve results faster than with Magento. If I can, then maybe I will offer this solution to my clients.
For that specific component I need all that data anyway. Other components are already separated.
Now I am getting all that data within 572ms, which is about the same as the exact same thing on Magento after caching (hardware is exactly the same). Without cache Magento loads that component out in 1.2 seconds.
If you say that with parallelization I could improve that number further, then I will look into it later. My logic is, that those multiple requests should happen as close to the Aimeos API as possible (or even as close to the actual database).
There is another improvement too. On Magento it takes 130 requests to load that page. My implementation cuts the amount of requests by 90% and I have not yet done any optimization or minification. All of that with no loss in usability. I would even say that the usability is actually better.
If we talk about combining aggregations, the at first glance I think they can be combined. Each returned result has "type" attribute. Based on that I can easily differentiate them.
Here is the picture:
matish
Post by matish » 28 Nov 2025, 17:05
I am working with categories now and already I have a question.
https://aimeos.priit.yt.lan/jsonapi/catalog?id=5&include=catalog%2Cmedia%2Ctext
Consider this picture as a response to the URL above:
I can clearly see that the category "Lenovo sülearvutid" has no children. But what about parents? On Magento there is a "path" column for the catalog_category_entity database table (example value: 0/2/5) from which I can easily locate the parents. Do you have something similar on the API too?
I need this information so I could build out the breadcrumbs.
On Aimeos default application breadcrumbs work as long as the customer is under category view, but once product view is opened, the breadcrumb does not work.
It did not work on default Magento 2 too, but I have fixed it for some customers and it has brought them more customers as a result of that.
Here is another picture that clarifies what I mean:
Post by aimeos » 01 Dec 2025, 15:39
matish wrote: 28 Nov 2025, 15:06
Yes, because "[]" assigns a consecutive number automatically in PHP.
Further optimization in your setup seems to be only possible by fetching the data from the JSON API in parallel. Normally, I would suggest to use the aggregation endpoints from Javascript code in the frontend but your domains for HTML and API are different, which would result in doubling the requests due to browser sending CORS pre-flight request for each real request. The only solution for that would be to "mount" the JSON API into the same domain as the HTML generating code.
From that persective, you may be right. The JSON:API spec says you can but you shouldn't do that.
Post by aimeos » 01 Dec 2025, 15:56
matish wrote: 28 Nov 2025, 17:05 I can clearly see that the category "Lenovo sülearvutid" has no children. But what about parents? On Magento there is a "path" column for the catalog_category_entity database table (example value: 0/2/5) from which I can easily locate the parents. Do you have something similar on the API too?
The parent categories are not available explicitely because
- Products can be assigned to multiple categories
- Aimeos doesn't have a "main" category
- Retrieving categries up to the root category can be costly
But you can display the current category by passing the category ID to the product detail view if you fetch the categories for the menu nevertheless. You only have to set the canonical URL correctly to avoid duplicate content.
matish
Post by matish » 03 Dec 2025, 13:02
Thank you for your response. I had to make a bit of custom development because of that.
I did a procedure, that imports all categories and indexes them accordingly. Now I can retrieve all I need quickly. Response is still 0.550ms, so all is good.
Rendering this kind of category menu is really easy. Only the top level nodes are loaded initially and each subsequent sublevel content loading happens on "onmouseover once". This kind of approach should check all the boxes regarding to speed and minimum amount of data.
If there is no "main" category, then you can make a arbitrary root. It is just an extra database entry, nothing else.
If the same product can belong to multiple categories, then at the product view it is possible to render 2 separate breadcrumbs, each one indicating a separate path.
If only one breadcrumb is possible and it is not known where the user came in from, then I have rendered the breadcrumb which has the longest path.
Merchants definitely love breadcrumbs and they say, it is 21st century, time of AI, how are you saying that breadcrumbs are not possible?
They have a good reason too. Most of the customers find products from the advertisements. But it may be so that they do not like the initial product, maybe they want a different color of the same kind of product and if there is no breadcrumb, then this customer will most likely leave with no purchase, since there are trillion items in the shop and this will just confuse the customer. Especially if the merchant has not invested enough to make the search good enough to be actually useful. Good breadcrumbs are always cheaper to implement than a good search.
Playing around categories revealed that Aimeos category rendering is different from my expectations.
First of all, there is no way to access "Second home" category over the API.
Initial starting point:
https://aimeos.priit.yt.lan/jsonapi/catalog?include=catalog%2Cmedia%2Ctext
Secondly, categories deeper than level 4 are never loaded. (Over the API I managed to get all levels, except for the "Second home" category)
And thirdly, if there is a product available in subcategory (like T2-2-1) and customer is viewing its direct parent (like T2-2) then this product is not findable in it. On Magento this behaviour is different via "is_anchor" attribute.
Picture:
For now you can consider those findings as information. Those things do not affect my development, except for the third issue, that affects category view implementation when certain category is chosen. I guess one way is to supply ID-s of all subcategories with OR condition, but I may need to index that separately.
matish
Post by matish » 16 Feb 2026, 15:37
Well, I think I got the first version running:
https://shop-api.aktsia.ee/
It uses Laravel + HTMX + Bootstrap. Products come directly from AimeOS and AimeOS site itself is on a totally different domain.
Customer login is not done in this example.
What works:
* Product listing with filtering (that includes overlay filter)
* Product search
* Product comparison (if you are in list view, you can easily differentiate which products are in comparison and which are not)
* Cart
* Checkout (order details are sent to AimeOS after payment has been successful, customer is asked for less details if it chooses pickup as delivery option).
* Payment methods are connected to test-accounts. So feel free to place orders.
* Coupon code SUPERSOODNE should work
* Contact us page (except for the form)
What does it do:
* Reads products from AimeOS
* Uses AimeOS cart
* Uses AimeOS to place orders from the cart.
* Payment and shipping method is simple custom AimeOS Service method, which collects payment/shipping information from shop_api and injects it into the order details.
* Customer has no direct access to AimeOS instance
* Product comparison is not handled by AimeOS. It is kept in session.
Loose ends:
* Order does not get authorized after placement
* Only 1 coupon code allowed with no user readable error message available For now I put hardcode fix.
* Category loading was a bit different too, but I created a local category tree copy.
All of this took 42 days of my work. It was first time working with AimeOS, HTMX and Laravel.
I managed to reduce the amount of Javascript by a lot. I still have some files, but I do not have to think anymore where what function should go. Page inteactivity is very good and you can make any e-commerce flow you like.
End result turned out to be even faster than I anticipated. Cart API implementation is really good, because in most of the cases it returns the cart in the exact same format. Meaning less re-loads after cart modification and a faster site.
Compared to Magento overall implementation seems to be easier because in Magento you can not get all needed data via one API. You need multiple API-s (graphql, json, admin-json) to get all needed data and when going back to version 2.3, then some of the data may not be available at all. Also Magento is a lot slower on the exact same hardware.
Overall I think that if you have an e-shop that sells to max 3..4 countries, then this approach is worth considering over making a custom Magento or AimeOS theme. Because there are so many rules in themes, that you need to follow, which may turn out to be a lot more expensive compared to the lightweight API based approach, where you have total control over the design and flow.
