Multi-vendor Ecommerce with Aimeos?
nos3
Re: Multi-vendor Ecommerce with Aimeos?
Post by nos3 » 21 Jan 2018, 11:58
In an Aimeos standard setup, you can create as many shops as you like. Each one is separate from each other but they all share the same configuration and templates.
The ai-sites extension we are offering enables you to create a tree of sites of unlimited depth and width below each of the sites from a standard installation. These child sites can inherit data from their anchestor sites and add additional data like differen prices, texts, images, attributes, etc. This is usefull if you have different portals that share common product data like in many B2B scenarios. Furthermore, you can configure the extension to aggregate data from child sites into the top level sites or any site in between. Thus, you can build a market place or several market places at different site levels. Our extension is very flexible in what it allows you to do, so you can totally configure it according to your needs.
hihaider196
Post by hihaider196 » 11 Jan 2019, 14:13
How can we add seller functionality in aimeos? or just want to make simple buy and sell in simple words will aimeos be helpful?
Post by aimeos » 14 Jan 2019, 13:21
Multiple shops without data inheritance are available out of the box in Aimeos:
https://aimeos.org/docs/Laravel/Configu ... iple_shops
randipdhiman
Post by randipdhiman » 15 Mar 2019, 05:21
How many shops can be created with AIMEOS? Moreover, is it possible to add different payment gateway for every shop?
Post by aimeos » 15 Mar 2019, 09:41
There's no limit in shops you can create in one installation and yes, you can have different payment/delivery options in each shop.
attinder
Post by attinder » 13 Apr 2020, 09:22
How many shops we can create with Aimeos?
Post by aimeos » 13 Apr 2020, 09:23
Unlimited :-)
