Post by aimeos » 16 Nov 2022, 11:49
Think, we've found the error. Can you please try this pre-release?
https://aimeos.org/fileadmin/download/a ... 3-pre1.zip
Moritz
Post by Moritz » 16 Nov 2022, 12:11
Thank you very much!
In a fresh Typo3 environment the installation is successfully now.
But on the system of our clients I get the following error when installing.
The value in mshop_order.relatedid of every record is NULL.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Post by aimeos » 16 Nov 2022, 12:22
Why does the mshop_order.relatedid column use DATETIME instead of VARCHAR?
At least it seems to do so according to the error output.
Moritz
Post by Moritz » 16 Nov 2022, 12:27
Good question, I hope you can give me the answer 🙂
Maybe in the migration the SQL parameter is bind as datetime or something like that?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 16 Nov 2022, 12:42
What's the output of "SHOW CREATE TABLE mshop_order" at that database?
Moritz
Post by Moritz » 16 Nov 2022, 12:48
This is the output of the statement on the production system (v18.10.11) our clients, on which we try the upgrade.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 16 Nov 2022, 13:00
Seems like an error due to the setup task order. Can you try this pre-release package?
https://aimeos.org/fileadmin/download/a ... 3-pre2.zip
Moritz
Post by Moritz » 16 Nov 2022, 13:25
Now the migration on our clients system was successfully.
I appreciate your awesome support.
PHP 8.2.24
Typo3 v12.4.23 LTS
boettner
Post by boettner » 16 Nov 2022, 15:55
With aimeos_22.10.3-pre2 I still get the error we discussed by PM which is similar to this one from Moritz:
Moritz wrote: 11 Nov 2022, 12:18 I upgrade on the clients test machine and get another error in the upgrade wizard.
My error:
(1/1) Aimeos\Base\DB\Exception
SQLSTATE[42S22]: Column not found: 1054 Unknown column 't3feu.cnum' in 'field list': SELECT t3feu."cnum", t3feu."shipping_conditions", t3feu."shipping_info", t3feu."fca_threshold", t3feu."payment_terms", t3feu."payment_type", t3feu."department", mcus."uid" AS "customer.id", mcus."siteid" AS "customer.siteid", mcus."name" AS "customer.label", mcus."gender" AS "customer.salutation", mcus."username" AS "customer.code", mcus."title" AS "customer.title", mcus."company" AS "customer.company", mcus."vatid" AS "customer.vatid", mcus."first_name" AS "customer.firstname", mcus."last_name" AS "customer.lastname", mcus."address" AS "customer.address1", mcus."zip" AS "customer.postal", mcus."city" AS "customer.city", mcus."zone" AS "customer.state", mcus."static_info_country" AS "customer.countryid", mcus."language" AS "customer.languageid", mcus."telephone" AS "customer.telephone", mcus."email" AS "customer.email", mcus."fax" AS "customer.telefax", mcus."www" AS "customer.website", mcus."longitude" AS "customer.longitude", mcus."latitude" AS "customer.latitude", mcus."password" AS "customer.password", mcus."date_of_birth" AS "customer.birthday", mcus."usergroup" as "customer.groups", mcus."pid" AS "typo3.pageid", mcus."disable" AS "customer.status", mcus."crdate" AS "customer.ctime", mcus."tstamp" AS "customer.mtime" FROM "fe_users" as mcus WHERE ( ( mcus."siteid" IN ('','1.') ) AND ( ( mcus."uid" IS NULL ) AND ( mcus."disable" = 0 ) ) ) AND mcus."deleted" = 0 GROUP BY mcus."uid", mcus."uid", mcus."static_info_country" ORDER BY mcus."uid" ASC LIMIT 100 OFFSET 0
The Upgrade Wizard finishes successfully with no errors and the columns are present in the database. They already have been migrated from 18 > 20 > 22 but the error occurs here.
Backend runs fine.
We are using ai-customergroups, could that interfere?
Post by aimeos » 17 Nov 2022, 01:38
Your SQL statement uses two different table aliases, "t3feu" and "mcus" while only "mcus" is defined.
