Add price after pressing "add to basket" button
lucadambros
Re: Add price after pressing "add to basket" button
That worked!aimeos wrote: 27 Aug 2019, 14:35 Alternatively, if all your products can be bought, you can remove the Category frontend basket decorator:
https://aimeos.org/docs/Configuration/C ... tors/local
Thank you very much for your help!
