Payment Gateway WechatPay
Re: Payment Gateway WechatPay
Post by aimeos » 07 Feb 2022, 16:12
Your config/shop.php is OK. In the latest stack trace, the error originates from:
https://github.com/aimeos/ai-client-htm ... rd.php#L66
But this is only where the error is written to the output, not the exception itself.
godadada@yahoo.com
Post by godadada@yahoo.com » 07 Feb 2022, 23:37
Thanks.
I think it blows up here. looking for a file body-standard.blade.php that does not exist.
I am not sure if I should provide that file or that file should not be called for.
Regards,
Post by aimeos » 09 Feb 2022, 08:02
The view implementation tests if there's a body-standard.blade.php file available and prefers it over a body-standard.php but that should be not a problem and is also not related to your initially posted error message.
godadada@yahoo.com
Post by godadada@yahoo.com » 10 Feb 2022, 02:02
The issue is with wechat credential. Thanks
godadada@yahoo.com
Post by godadada@yahoo.com » 11 Feb 2022, 06:17
Greetings,
in the method getData
$data['spbill_create_ip'] = $this->getValue( 'client.ipaddress' );
is null.
Anyway to fix it?
Regards,
godadada@yahoo.com
Post by godadada@yahoo.com » 12 Feb 2022, 08:30
I tried also PaypalPlus and PaypalExpress. The former has the same issue of 'client.ipaddress' to be null and the later is built in and does not call the Omnipay::getData.
Regards,
godadada@yahoo.com
Post by godadada@yahoo.com » 14 Feb 2022, 01:22
Figured this one out. client.ipaddress needs to be set in the payment configuration.
I still get payment failure though. Trying to find out where the issue is.
Regards,
Post by aimeos » 14 Feb 2022, 07:54
Laravel should return the client IP address here:
https://github.com/aimeos/ai-laravel/bl ... l5.php#L48
If not, then it's something you need to check in the Laravel code.
godadada@yahoo.com
Post by godadada@yahoo.com » 05 Mar 2022, 05:15
Sorry, I do not know enough to answer CCavenue question. I am still struggling with WechatPay.
I am able to make some progress, got SUCCESS response from WechatPay gateway (see attached imageJ).
But it still gave error at the end>
godadada@yahoo.com
Post by godadada@yahoo.com » 05 Mar 2022, 09:02
It seems complaining the frontend::create first parameter '$context' has cache to be null.
Regards,
