Separate mails for shop owner and customer - no bcc
boettner
Re: Separate mails for shop owner and customer - no bcc
Post by boettner » 05 Aug 2020, 14:03
Try placing it in your "ai-html-client" ext directory from where all other custom classes/templates get called correctly. At the same level of the client directory:
From there: /lib/custom/src/MShop/Service/Provider/Delivery/Email.php
daniel
Post by daniel » 05 Aug 2020, 14:25
ok, so now i don't have the error any more.
In my Service for delivery i want to add the Decorator. But now it's in the "main"-list like "Standard" and "xml", see screenshot. I think it should be selectable under ("+"), not?
If i add "Email" (so i have "Standard,Email") in the frontend (checkout) i still got the error "Class "\Aimeos\MShop\Service\Provider\Decorator\Email" not available"
Sorry, i'm not a backend developer...
Bildschirmfoto 2020-08-05 um 16.11.54.png (13.81 KiB) Viewed 12482 times
boettner
Post by boettner » 05 Aug 2020, 14:35
Did you maybe mix up class type and class location ?
Decorators go into: MShop\Service\Provider\Decorator
Provider into: MShop\Service\Provider\Decorator\Delivery (or ... Payment)
The classes must extend core classes respectively.
daniel
Post by daniel » 05 Aug 2020, 14:45
i think so... i'm a bit confused. I need an Email that goes to the shop owner if the scheduler task for order payment / order delivery is executed. I thought i need a Decorator for that... and i think now i have a provider...
It is not clear to me what i need, as the posts before i think i need a Decorator:
"You should write an "Email" decorator for the service providers that sends an e-mail to the configured address"
I will set back my changes to the point i had the selection of the Email Decorator.
boettner
Post by boettner » 05 Aug 2020, 14:53
daniel wrote: 05 Aug 2020, 14:45 I will set back my changes to the point i had the selection of the Email Decorator.
Yes, and place it in the Decorator directory mentioned above and extend it like so:
<?php
 * @copyright Metaways Infosystems GmbH, 2011
 * @copyright Aimeos (aimeos.org), 2015-2018
 * @package MShop
 * @subpackage Service
namespace Aimeos\MShop\Service\Provider\Decorator;
 * Your Decorator
 * @package MShop
class Email
    extends \Aimeos\MShop\Service\Provider\Decorator\Base
    implements \Aimeos\MShop\Service\Provider\Decorator\Iface
daniel
Post by daniel » 06 Aug 2020, 06:53
Good morning,
now i set it up and got no more errors. I add the Decorator to my Service type "delivery" > "Standard,Email".
But how this would be triggered when executing the scheduler task. I add a function "processBatch" (like recommended in previous post) where i output a log, but nothing happens (also tested with a die(); to stop executing), I think this would never be triggered...
boettner
Post by boettner » 06 Aug 2020, 07:29
Good morning,
everything you are doing should be ok according to previous posts. You are working in a TER installation, right? Meaning not in composer mode? Do you see your class included in typo3conf/autoload/autoload_classmap.php?
As I didn´t do my own implementation yet, I unfortunately can´t offer any blueprint atm.
daniel
Post by daniel » 06 Aug 2020, 08:00
yes, TYPO3 10 with actual version of the aimeos ext form ter.
no, in the autoload_classmap.php it's not included, i only found Email.php file for
'Aimeos\\Aimeos\\Scheduler\\Provider\\Email' => $typo3InstallDir .typo3conf/ext/aimeos/Classes/Scheduler/Provider/Email.php',
'Aimeos\\Aimeos\\Scheduler\\Provider\\Email6' => $typo3InstallDir . 'typo3conf/ext/aimeos/Classes/Scheduler/Provider/Email6.php',
But also the other (default from aimeos ext) decorators are not in the autoload_classmap.php, is it neccessary that my class is included?
i checked the files in aimeos ext where the emails for payment are sent: ai-client-html/controller/jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php
for delivery: ai-client-html/controller/jobs/src/Controller/Jobs/Order/Email/Delivery/Standard.php
maybe i should overwrite one of these if it's possible?
boettner
Post by boettner » 06 Aug 2020, 08:12
Did you rebuild/dump the autoload information from the BE Maintenance module and clear the caches afterwards?
daniel
Post by daniel » 06 Aug 2020, 09:00
yes, sure. i don't think this should be in autoload_classmap, other decorators (from aimeos shop) are also not included.
