Aimeos installation from composer works but stop executing before database setup
octorber123
Re: Aimeos installation from composer works but stop executing before database setup
Post by octorber123 » 22 Jul 2020, 11:44
only one problem tho, I set up the admin account during setup, however when I log in i can't access the backend, it seems that it is treating me like a customer, how can I fix that?
octorber123
Post by octorber123 » 22 Jul 2020, 11:47
i have tried the new composer create-project aimeos/aimeos:2019.10.x-dev myshop and the setup works perfectly. However there is a confusing question: Do you want to remove the existing VCS (.git, .svn..) history? [Y,n]? like I don't know what the means
Post by aimeos » 22 Jul 2020, 12:08
octorber123 wrote: 22 Jul 2020, 11:44 only one problem tho, I set up the admin account during setup, however when I log in i can't access the backend, it seems that it is treating me like a customer, how can I fix that?
Can you post the record from the users table?
octorber123 wrote: 22 Jul 2020, 11:47 i have tried the new composer create-project aimeos/aimeos:2019.10.x-dev myshop and the setup works perfectly. However there is a confusing question: Do you want to remove the existing VCS (.git, .svn..) history? [Y,n]? like I don't know what the means
I think, that will go away when the new release is tagged.
octorber123
Post by octorber123 » 22 Jul 2020, 12:49
here is the users table
This is the first page i see when i log in as an admin, also why is the area highlighted empty?
this is the front page (again you can see that area is empty
Post by aimeos » 22 Jul 2020, 12:58
Everything seems to be OK. To go to the admin backend, you have to explicitely use the /admin URL in your browser. If you use the Laravel login link, you will only get redirected to the profile page because admins are also regular users.
The empty area right of the small basket symbol is due to sliding in the small basket content.
octorber123
Post by octorber123 » 22 Jul 2020, 13:07
Thanks a lot for your help
