language form-add new field
Re: language form-add new field
i have tried that but when i extend from sites these methods in manager do not workaimeos wrote: 30 Jan 2021, 10:31 Don't extend from the Standard locale site manager class if you are using the ai-sites extension:Instead, extend from the "Sites" class of that extension:Code: Select all
class Myproject extends StandardCode: Select all
class Myproject extends Sites
public function getSearchAttributes( bool $withsub = true ) : array
$list = parent::getSearchAttributes( $withsub );
foreach( $this->searchConfig as $key => $fields ) {
$list[$key] = new \Aimeos\MW\Criteria\Attribute\Standard( $fields );
return $list;
protected function createItemBase( array $data = [] ) : \Aimeos\MShop\Locale\Item\Site\Iface
return new \Aimeos\MShop\Locale\Item\Site\Myproject( $data );
}Re: language form-add new field
hey aimeos,aimeos wrote: 30 Jan 2021, 10:31 Don't extend from the Standard locale site manager class if you are using the ai-sites extension:Instead, extend from the "Sites" class of that extension:Code: Select all
actually i have extended my manager from Sites class but method
please guide me which method should i use instead of createItemBase when extending from Sites class because it is not
working as you know it is a protected method from Standard Class
hey aimeos can please have a look on that problem
If you haven't added a \Aimeos\MShop\Locale\Item\Site\Myproject class yet, you should do that like described in the docs:
https://aimeos.org/docs/latest/infrastr ... ers/#items
