Code Required error when registering
Re: Code Required error when registering
Not bad for a days work (well, you did all of it...)aimeos wrote: 19 Dec 2022, 14:34 Maybe it must be:Code: Select all
use Illuminate\Support\Facades\Request;
Thank you. Its working now!
Bug. When billing 'order.base.address.languageid' is null, then Registration email will not be sent out.
this is the problem:
I don't have 'en' language.
must be recorded in shop.php
$helper = new \Aimeos\Base\View\Helper\Translate\Standard( $view, $this->context()->i18n( $langId ?: 'en' ) );must be recorded in shop.php
'client' => [
'html' => [
'checkout' => [
'standard' => [
'address' => [
'billing' => [
'hidden' => [
