Aimeos Create an new extension and Api in it.
TEJASPARMAR
Re: Aimeos Create an new extension and Api in it.
Post by TEJASPARMAR » 09 Jul 2024, 17:52
aimeos wrote: 04 Jul 2024, 09:44 If you copy the existing theme into a new directory besides, you can create a new theme that will be published to ./public/vendor/shop/themes/
I have created a new theme like this.
What do we have to do to publish it in the public folder?
Is there any command to run or anything else?Image[/img]ImageImage
Screenshot from 2024-07-09 23-48-13.png (16.68 KiB) Viewed 16249 times
Post by aimeos » 11 Jul 2024, 07:30
This command will publish the files to the ./public/vendor/ directory and it will be automatically executed if you run "composer update":
https://github.com/aimeos/aimeos/blob/m ... r.json#L63
Post by aimeos » 11 Jul 2024, 07:31
TEJASPARMAR wrote: 09 Jul 2024, 17:31 Getting this error for security policy.
Can please help me for that ?
All your JS code must be in a JS file that is included, inline JS isn't allowed.
TEJASPARMAR
Post by TEJASPARMAR » 15 Jul 2024, 13:07
I have overridden the checkout template by my own HTML template based on some conditions.
I getting this error on that page.
"A non-recoverable error occurred ".
Can you please help me or give some suggestions about it?
Post by aimeos » 17 Jul 2024, 11:34
Have a look into the Log panel of the admin backend. There you will find more details about the error.
TEJASPARMAR
Post by TEJASPARMAR » 26 Jul 2024, 10:25
There is no logs for the error there.
Post by aimeos » 28 Jul 2024, 09:22
There must be one because for "A non-recoverable error occurred" an entry is always written to the madmin_log table.
