Update 22 to 24 Errors
randomdennis
Re: Update 22 to 24 Errors
I was able to solve the URL problems with a suitable trusted host pattern.
I almost understand that with the invoices, is the payment status now only to be found in the order list-view? This was previously in the “Invoices” window, which is now "Transactions".
The system seems to be working now, except that I get the message: “Class ‘Aimeos\Bootstrap’ not found” when i try to Check TCA Migrations in the Backend as Ajax Error.
Thank you very much for your comprehensive help, we really appreciate it.
The data from the previous "Invoices" sub-panel has been merged into the "Basic" sub-panel as the mshop_order and mshop_order_base tables have been merged.randomdennis wrote: 12 Dec 2024, 13:55 I almost understand that with the invoices, is the payment status now only to be found in the order list-view? This was previously in the “Invoices” window, which is now "Transactions".
You have a TYPO3 legacy setup, not a composer based setup, right?randomdennis wrote: 12 Dec 2024, 13:55 The system seems to be working now, except that I get the message: “Class ‘Aimeos\Bootstrap’ not found” when i try to Check TCA Migrations in the Backend as Ajax Error.
