Payment Gateway WechatPay
Re: Payment Gateway WechatPay
That's not the problem. You have to find the ksort() call that recevies a NULL value instead of an array.
godadada@yahoo.com
the Omnipay\WechatPay::getData was called and null return passed to ksort routine. (see attached call stack).
I am not sure if this version of getData is the right one to call.
Regards,
Regards,
- wechatgetdata.png (179.3 KiB) Viewed 5731 times
Is the XML string invalid so "Helper::xml2array()" returns NULL?
godadada@yahoo.com
$data = $this->getRequestParams(); returns null, which is the input $data for Helper::xml2array(), then also returning null.
regards,
regards,
- xml2aray.png (84.47 KiB) Viewed 5722 times
Seems like you have to set this parameters first:
https://github.com/lokielse/omnipay-wec ... notify-doc
Unfortunately, this Omnipay driver is far from the standard :-/
godadada@yahoo.com
much appreciated input.
I have over-ridden the Omnipay::updateSync method, and added one line to obtain 'request_params'. but it complained xml2array failure.
Please enlighten.
Regards,
Please enlighten.
Regards,
- WeChatPay updateSync.png (191.78 KiB) Viewed 5245 times
- xml2aray.png (84.47 KiB) Viewed 5245 times
