Integrate aimeos with angular 2 and ionic framework
VickoNovianto
Post by VickoNovianto » 19 Jun 2017, 09:33
How do I integrate aimeos with angular 2(frontend for desktop) and ionic framework(frontend for mobile apps)?
Re: Integrate aimeos with angular 2 and ionic framework
Post by aimeos » 19 Jun 2017, 09:50
Use the new Aimeos JSON REST API for mobile and JS single page applications:
https://aimeos.org/docs/Developers/Client/JSONAPI
Documentation about handling the basket, checkout process and order will be added before the upcoming release beginning of July.
VickoNovianto
Post by VickoNovianto » 21 Jun 2017, 01:41
How to configure the base URL to the Aimeos JSON API?
Post by aimeos » 21 Jun 2017, 13:12
The default route is /jsonapi for Laravel:
https://github.com/aimeos/aimeos-larave ... s.php#L108
