Hide all products in 'list' page
tkristis
Environment - Linux,
PHP - 7.0.22,
Aimeos - 2017.07,
Laravel - 5.5.19.
I want to hide all products which are in 'list' page and leave just search bar with categories.
Like I understand I need to work with config/shop.php file, but I can't find information how to achieve that what i want.
Any help?
PHP - 7.0.22,
Aimeos - 2017.07,
Laravel - 5.5.19.
Any help?
Re: Hide all products in 'list' page
Simply remove the "catalog/lists" part from the page you want this to happen:
https://github.com/aimeos/aimeos-larave ... op.php#L21
Most probably you want to create a new page. Then, please have a look into these articles:
https://aimeos.org/docs/Laravel#Pages
tkristis
But if I delete 'catalog/lists' then all products be hidden, even if I open any category.
I want to hide all products just from landing list page, but keep it in categories.
So if I want to do this I need to create a new page or there is another way?
Best is to create a new page for this.
An alternative would be to configure a default category ID of a category that has no products:
https://aimeos.org/docs/Configuration/C ... id-default
tkristis
I created controller ProductsController.php
config/shop.php
index.blade.view
Route
So far everything works fine, but page don't have Aimeos css styling and js.
Also categories not showing how many products in it.
Could you help me with that?
<?php
namespace App\Http\Controllers;
use Illuminate\Http\Request;
class ProductsController extends Controller
public function index()
$params = app( '\Aimeos\Shop\Base\Page' )->getSections( 'index' );
// do some more stuff
return \View::make('index', $params);
'index' => [ 'catalog/filter' ]Code: Select all
@extends('app')
@section('content')
<?= $aibody['catalog/filter'] ?>
@endsection
Route::get('products', 'ProductsController@index');Also categories not showing how many products in it.
Change your Blade template to this:
The aimeos_header will contain the tags for retrieving the product counts and extending from "base" template will add you Aimeos CSS and JS: https://github.com/aimeos/aimeos-larave ... .blade.php
@extends('base')
@section('aimeos_header')
<?= $aiheader['catalog/filter'] ?>
@stop
@section('aimeos_nav')
@endsection
tkristis
Thank you, now it shows how many products in each category.
But problem is that base template can't be found.
Maybe it's because I created index.blade.php template in app/resources/views?
But it must be in app/ vendor/aimeos/aimeos-laravel/src/views ?
That might be the case. Please have a look into the Laravel documentation how it exactly works.
