Selection Menu
mattdev
Selection Menu
Post by mattdev » 27 Nov 2017, 16:29
is there a way through the UI to setup options in a selection menu that would show another selection menu based off from the value from the first selection menu?
Re: Selection Menu
Post by aimeos » 27 Nov 2017, 22:13
Can you make a practical example?
mattdev
Re: Selection Menu
Post by mattdev » 27 Nov 2017, 22:34
Yes If I have a logo selection and I want the customer to choose from either a stock logo or a custom logo. I would want the stock logo choice to show a selection that would all of the stock logos listed for them to choose from.
Re: Selection Menu
Post by aimeos » 28 Nov 2017, 22:15
Does changing this configuration for your attribute types to "radio" is what you need?
https://aimeos.org/docs/Configuration/C ... ibute/type
If not, you can always adapt the template as you need:
https://github.com/aimeos/ai-client-htm ... t.php#L104
