thumb-picture-link in the detail-view
Stefan80
Post by Stefan80 » 01 Mar 2018, 12:36
is it possible to change/remove the anchor-link, when I click a thumb-picture?
thanks
Re: thumb-picture-link in the detail-view
Post by aimeos » 02 Mar 2018, 08:52
The anchor links are used to slide to the corresponding large picture. That won't work any more if you remove the anchors.
Stefan80
Post by Stefan80 » 02 Mar 2018, 09:01
We have a fixed navigation that covers the shoppicture.
http://faktura-berlin.de/shop-allgemein ... _Muster/2/
the picture must jump a little lower.
Post by aimeos » 04 Mar 2018, 11:04
We've added a configuration for that in dev-master. You can overwrite the JS method by your own in the meantime:
https://github.com/aimeos/ai-client-htm ... a8b4bfadf3
