Invalid response when updating things in admin view
NicolasLapointe(ComradeNixco)
Post by NicolasLapointe(ComradeNixco) » 27 Apr 2018, 18:26
I have this error that appears when I try to edit or delete entries in the admin view:
The controller must return a response (Object(Aimeos\MW\View\Helper\Response\Symfony2) given).
500 Internal Server Error - LogicException
It can be noted that the actions is still done (I.E.: The product is removed), I just have to go back and reload the page
I run Aimeos 2018.04 latest non-dev with symfony 2.8 in production with apache 2.4, php 5.6.35 via Wampserver (windows).
Re: Invalid response when updating things in admin view
Post by aimeos » 27 Apr 2018, 19:30
Can you please execute "composer update" again? You should get "aimeos/ai-admin-jqadm" version 2018.04.9 which fixes the problem.
Post by NicolasLapointe(ComradeNixco) » 30 Apr 2018, 16:57
Sadly upgrading didn't correct the problem in my app.
here's my composer.json:
    "name": "symfony/framework-standard-edition",
    "description": "The \"Symfony Standard Edition\" distribution",
    "autoload": {
        "psr-0": { "": "src/" }
    "require": {
        "php": ">=5.6.31",
        "symfony/symfony": "2.8.*",
        "doctrine/orm": "~2.2,>=2.2.3",
        "doctrine/doctrine-bundle": "~1.4,>=1.4.0",
        "twig/extensions": ">=1.5.0",
        "symfony/assetic-bundle": "~2.3,>=2.3.0",
        "symfony/swiftmailer-bundle": "~2.3,>=2.3.0",
        "jms/security-extra-bundle": "~1.6,>=1.6.0",
        "jms/di-extra-bundle": "~1.4",
		"jms/payment-core-bundle": "1.1.0",
		"jms/payment-paypal-bundle": "1.0.0",
        "twbs/bootstrap": "~3.3,>=3.3.7",
        "sensio/framework-extra-bundle": "~2.3",
        "stof/doctrine-extensions-bundle": ">=1.2",
        "friendsofsymfony/user-bundle": ">=1.3.7",
        "orderly/paypal-ipn-bundle": "dev-master",
        "egulias/email-validator": "~1.2",
        "symfony/monolog-bundle": "~2.4",
        "aimeos/aimeos-symfony": "~2018.04@dev"
    "require-dev": {
        "sensio/distribution-bundle": "~2.2,>=2.2.0",
        "doctrine/doctrine-fixtures-bundle": ">=2.3.0",
        "sensio/generator-bundle": "~2.2,>=2.2.0"
    "scripts": {
        "post-install-cmd": [
            "Aimeos\\ShopBundle\\Composer\\ScriptHandler::installBundle",
            "Aimeos\\ShopBundle\\Composer\\ScriptHandler::updateConfig",
            "Aimeos\\ShopBundle\\Composer\\ScriptHandler::setupDatabase",
            "Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::buildBootstrap",
            "Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::clearCache",
            "Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::installAssets",
            "Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::installRequirementsFile"
        "post-update-cmd": [
    "config": {
        "bin-dir": "bin"
    "extra": {
        "symfony-app-dir": "app",
        "symfony-bin-dir": "app",
        "symfony-var-dir": "var",
        "symfony-web-dir": "web"
also a picture of the installed packages is attached to this reply
The error page
The error page
Post by aimeos » 02 May 2018, 08:06
Can you try to add the Symfony PSR-7 bridge?
http://symfony.com/doc/current/components/psr7.html
Post by aimeos » 02 May 2018, 08:35
Resp. can you post the output of "composer show"?
Post by NicolasLapointe(ComradeNixco) » 02 May 2018, 14:27
FInally, I opted to separate the shop from the main wweb site, now the shop runs on symfony 3 and it works perfectly. I'll see to show you the result of what you asked, but it'll have to wait, sorry.
