Bug in aimeos.js
etienne.bonnin
Bug in aimeos.js
Post by etienne.bonnin » 07 Jun 2018, 16:04
In my environment the ajax calls setupWatchAction and setupFavoriteAction do not work!
I suggest adding:
dataType: 'html'
inside ajax calls. I do not know why in my environment the script does not work but I imagine it may depend on some versions of jquery. Maybe in your jquery version the html type is considered by default.
Regards.
Re: Bug in aimeos.js
Post by aimeos » 07 Jun 2018, 16:36
Can you create a pull request here?
https://github.com/aimeos/ai-client-html
