product images lost after saving in 2018.07
michal.fehér
Hi, I am using s3 storage for images (Digitalocean space). But when I save the product, even without doing any changes, product images are blank.
Any idea why this is happening?
- screen
- Snip20180705_7.png (177.67 KiB) Viewed 6677 times
Re: product images lost after saving in 2018.07
The image items are still there but the preview isn't shown? Is that the case?
If you store your images at a different server, you have to configure the base URL to your images using:
https://github.com/aimeos/aimeos-larave ... op.php#L58
michal.fehér
no, it's not in DB anymore. before that I could see images in frontend, after saving I can only see Aimeos logo
How do you create those images records? By importing them from the command line?
What data is posted to the server if you save a product? Can you check what happens here?
https://github.com/aimeos/ai-admin-jqad ... d.php#L330
michal.fehér
Thanks for the tip, I found out that default php.ini max_input_vars value (1000) was not enough when saving product with more variants. Increasing the value solved the problem.
