Artisan commands runs twice?
michal.fehér
Hi. I am not sure if this is normal, but I find it strange. When I am working with artisan commands, for example importing products from CSV or running services, and I dump anything, I get it twice in command line (see attached screenshot). This happens in each command, in every Aimeos version.
After command is finished, it doesnt seem to run twice. For example products are not imported twice, or services run 2 times in a row. Is that a bug or feature?
- Snip20180729_24.png (91.96 KiB) Viewed 15356 times
- Snip20180729_23.png (113.16 KiB) Viewed 15356 times
Re: Artisan commands runs twice?
The process() method is called as often as items need to be processed, only the run() method is called once when executing the artisan command
michal.fehér
It's the same when I dump it in run method:
- Snip20180730_29.png (25.9 KiB) Viewed 15352 times
- Snip20180730_28.png (20.35 KiB) Viewed 15352 times
We tested with
in the \Aimeos\Controller\Jobs\Order\Service\Delivery\Standard::run() method and it's only printed once. Do you have several sites the job controller is looping over?
echo __METHOD__;Professional support and custom implementation are available at Aimeos.com
michal.fehér
It's printed twice:
and this happens in every job, services, product imports etc. I only have 1 default site. Any idea why is this happening?
I would guess there's more than one site nevertheless. Can you have a look into the mshop_locale_site table if there's really only one record?
michal.fehér
Yes, there is only one record.
Anyway, if it would be the case of 2 sites, it would also be printed that way, not?
You can see from my screenshot:
If there are 2, I would expect something like
"Executing the Aimeos Job for default"
dump in run
dump in run
dump in run
"Executing the Aimeos Job for site2"
dump in runRe: Artisan commands runs twice?
Yes, that's true. Each site output would be printed separately.
There are three reasons why the same job is executed twice:
- For different sites (https://github.com/aimeos/aimeos-larave ... nd.php#L56)
- If the job name is twice in the list of jobs to execute (https://github.com/aimeos/aimeos-larave ... nd.php#L66)
- The job fails and it's automatically restarted (https://github.com/aimeos/aimeos-larave ... nd.php#L72)
"$process->start()" creates a new process that runs independently and if that fails, it's automatically executed again. This is the case in your situation because the job fails with status "256".
michal.fehér
Aha, indeed. dd() method makes it failed with error 256. if I just echo something and return true, then it runs just once. Thanks for clarification!
