Error saving product
jramirezgranada
Post by jramirezgranada » 10 Sep 2018, 19:20
When I'm saving a product new or existing i got this error:
An exception occurred while executing ' SELECT msupli."id" AS "supplier.lists.id", msupli."parentid" AS "supplier.lists.parentid", msupli."siteid" AS "supplier.lists.siteid", msupli."typeid" AS "supplier.lists.typeid", msupli."domain" AS "supplier.lists.domain", msupli."refid" AS "supplier.lists.refid", msupli."start" AS "supplier.lists.datestart", msupli."end" AS "supplier.lists.dateend", msupli."config" AS "supplier.lists.config", msupli."pos" AS "supplier.lists.position", msupli."status" AS "supplier.lists.status", msupli."mtime" AS "supplier.lists.mtime", msupli."editor" AS "supplier.lists.editor", msupli."ctime" AS "supplier.lists.ctime" FROM "mshop_supplier_list" AS msupli WHERE ( msupli."siteid" IN (1) AND ( msupli."refid" IN ('1') AND msupli."domain" = 'product' AND ( msupli."status" = 1 AND ( msupli."start" <= '2018-09-10 12:15:00' OR msupli."start" IS NULL ) AND ( msupli."end" >= '2018-09-10 12:15:00' OR msupli."end" IS NULL ) ) ) ) GROUP BY msupli."id", msupli."parentid", msupli."siteid", msupli."typeid", msupli."domain", msupli."refid", msupli."start", msupli."end", msupli."config", msupli."pos", msupli."status", msupli."mtime", msupli."editor", msupli."ctime" LIMIT 2147483647 OFFSET 0 ': SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
Note: the product is stored.
How can we solve it ?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Error saving product
Post by aimeos » 10 Sep 2018, 21:07
According to the error message it seems like you are using PostgreSQL. What happens if you execute the command from the PSQL client?
