Delivery address not copied over from Billing address
mmm
Post by mmm » 25 Sep 2018, 07:51
Windows 8.1
XAMPP
PHP 7.2.7
Laravel Framework 5.6.29
aimeos 2018.7
I am working on multi shop configuration. During Checkout process , while on address page I checked radio button 'as billing address' under Delivery address. This means to me that Billing address fields will be copied over to Delivery address but when I reached the summary page i get an error :
'Checks for available addresses in basket failed'
'The delivery address is missing'
Can you give me some hints towards the solution.
Regards/
Mubashir
Re: Delivery address not copied over from Billing address
Post by aimeos » 25 Sep 2018, 16:05
The delivery address isn't physically copied but the billing address is used instead if the delivery address isn't available. If you get an error that the delivery address isn't available at the summary page, you've probably configured the AddressAvailable basket plugin to enforce a delivery address being part of the order.
mmm
Post by mmm » 25 Sep 2018, 16:38
Thanks a lot for the hint.
It was AddressesAvailable plugin that when I disabled removed that error.
