How to add title field to user on creating order
SupportMantik
Post by SupportMantik » 09 Jan 2019, 08:16
Hello
I want to add title field from user table in address billing template. Is there way to do that?
Re: How to add title field to user on creating order
Post by aimeos » 09 Jan 2019, 10:20
Change the "mandatory" configuration for the addresses and include "order.base.address.title":
https://aimeos.org/docs/Configuration/C ... ut_address
mantik
Post by mantik » 09 Jan 2019, 10:28
Hello the question was: how we can extend the title field. (sorry my friend ask that not clear). we like to add company, mr, mrs, prof., dr.
Post by aimeos » 09 Jan 2019, 10:58
By default, the title field is an input field. You can change the template to use a select box with your values instead.
