basket takes long to load
stiller
Post by stiller » 17 Jan 2019, 22:25
hi there
when I add a product to the basket the basket overlay takes a long time to load.
I can only guess the hardware behind your demo shop where the basket appears much faster.
but on a vserver with 4GB RAM it often takes more than 5 sec.
also with the aimeos typo3 installation package with no further adjustments.
what can slow down the basket request?
is there a possibility to show an animated gif during this process so that the user receives some feedback on his action and keeps patience?
Re: basket takes long to load
Post by aimeos » 18 Jan 2019, 09:39
Is that only when adding something to the basket or also in the checkout process?
Possible problems:
- XDebug enabled
- OPCache disabled
- APCu not used
- Own basket plugin enabled that is called often and loads too much data from DB
stiller
Post by stiller » 20 Jan 2019, 16:09
yes, only when adding products. esp. the first one.
it sometimes takes more than 5sec
i'm using the standard basket
OPCache and APCu on
xdebug not loaded
how would it be possible to integrate a spinner.gif if no acceleration can be achieved
Post by aimeos » 21 Jan 2019, 09:31
There should be already an animated spinner icon shown by default due to:
- https://github.com/aimeos/ai-client-htm ... s.css#L219
- https://github.com/aimeos/ai-client-htm ... os.js#L593
We highly recommend to find out why it takes so long because that's not normal. You can see in the demo how fast it should be: http://typo3.demo.aimeos.org/demo/
Post by aimeos » 17 Sep 2019, 08:06
Did you already checked these sources of problems?
- open_basedir enabled
- XDebug enabled
- OPCache disabled
- APCu disabled and not enabled in Aimeos config
