Error on homepage
Indra
Error on homepage
Post by Indra » 11 Jun 2019, 01:15
Hi, after I install the aimeos, I receive this error.
Anyone know the errors?
Environment : MAC using MAMP
Screen Shot 2019-06-11 at 08.08.37.png (220.94 KiB) Viewed 6371 times
using postman
using postman
Screen Shot 2019-06-11 at 08.07.33.png (252.01 KiB) Viewed 6371 times
Re: Error on homepage
Post by aimeos » 11 Jun 2019, 07:36
Guess you changed the configuration and this isn't a valid array any more:
https://github.com/aimeos/aimeos-larave ... op.php#L27
Indra
Post by Indra » 11 Jun 2019, 14:22
Hi aimeos, actually I just finish the fresh install by following the documentation on aimeos laravel github, haven't change any configuration, I saw also the line you said commented on my file. Any idea on that error?
Post by aimeos » 11 Jun 2019, 21:58
Not yet. Can you add a
error_log( var_export( app( 'config' )->get( 'shop.page.catalog-stock' ) ) );
at
https://github.com/aimeos/aimeos-larave ... er.php#L87
and post the output from the console or Apache error log?
Indra
Post by Indra » 17 Jun 2019, 08:48
Hi aimeos, I already put the error log, but the output is empty. Any more idea?
Screen Shot 2019-06-17 at 15.47.28.png (121.98 KiB) Viewed 6323 times
Screen Shot 2019-06-17 at 15.45.56.png (103.1 KiB) Viewed 6323 times
Post by aimeos » 17 Jun 2019, 09:03
Sorry, must be:
error_log( var_export( app( 'config' )->get( 'shop.page.catalog-stock' ), true ) );
Without the "true", you won't get any output in the error log because it's directly written to the response.
