order product
yong
order product
Post by yong » 04 Jul 2019, 12:21
Hi, please what is the function (manager and item declaration ) to have the products item of an order ;
i'm using aimeos-laravel version 2018.10 in windows 10
Re: order product
Post by aimeos » 04 Jul 2019, 13:29
Where do you want to sort the products?
In the Frontend Controller it's the sort() method:
https://github.com/aimeos/ai-controller ... #L157-L164
In the MShop library you can sort by using:
$filter = $manager->createSearch();
$filter->setSortations( [$filter->sort( '+', 'product.label' )] );
yong
Re: order product
Post by yong » 04 Jul 2019, 13:42
Which manager i have to use ! i want the complete path for declaring the manager
Re: order product
Post by aimeos » 04 Jul 2019, 13:44
2019.x:
$manager = \Aimeos\MShop::create( $context, 'product' );
2018.x:
$manager = \Aimeos\MShop\Factory::createManager( $context, 'product' );
yong
Re: order product
Post by yong » 04 Jul 2019, 14:17
please, i mean u don't understand ! i have an order ID for a customer and i want for that order id (or item ) all the products of the customer order.
Re: order product
Post by aimeos » 04 Jul 2019, 14:25
That's something totally different:
$orderItem = \Aimeos\MShop::create( $context, 'order' )->getItem( '<id>' );
$orderBaseItem = \Aimeos\MShop::create( $context, 'order/base' )->getItem( $orderItem->getBaseId(), ['order/base/product'] );
$orderProductItems = $orderBaseItem->getProducts();
yong
Re: order product
Post by yong » 04 Jul 2019, 14:34
It seem this is not working for 2018.x version
Re: order product
Post by aimeos » 04 Jul 2019, 14:36
For 2018.10:
$orderItem = \Aimeos\MShop\Factory::createManager( $context, 'order' )->getItem( '<id>' );
$orderBaseItem = \Aimeos\MShop\Factory::createManager( $context, 'order/base' )->getItem( $orderItem->getBaseId(), ['order/base/product'] );
yong
Re: order product
Post by yong » 04 Jul 2019, 15:38
Thanks ! it's helpful
