Return Items You Ordered
Amber
Post by Amber » 09 Sep 2019, 07:51
How to create a return system like amazon? (https://www.amazon.com/gp/help/customer ... =201824330)
Re: Return products
Post by aimeos » 09 Sep 2019, 07:57
Rudimentary return management can be done in the order detail panel of the admin interface by setting the delivery status of each bought product. If you need more, you should use one of the return managment services offered as SaaS solution.
Amber
Re: Return Items You Ordered
Post by Amber » 09 Sep 2019, 08:16
If I am a customer, how can I return the items I ordered?
Post by aimeos » 09 Sep 2019, 08:30
You have to extend the account history component in the profile page to generate labels or whatever you need:
https://github.com/aimeos/ai-client-htm ... nt/History
Amber
Post by Amber » 10 Sep 2019, 02:30
>> Can you recommend something to me?
Amber
Post by Amber » 12 Sep 2019, 09:13
Can u recommend some return managment SaaS which is compatible Aimeos?
Post by aimeos » 12 Sep 2019, 09:25
We haven't integrated a return management SaaS yet. Thus, you have to write code to push the orders to the chosen return service yourself.
