No catalog node
frezno
No catalog node
Post by frezno » 07 Feb 2020, 23:41
Fresh installation of aimeos-laravel (2020.01) on a fresh Laravel (6.14)
Database import without demo data
when calling /shop the message
No catalog node for ID ""
shows up.
when trying to add first Category (home) an error message appears:
Symfony\Component\Debug\Exception\FatalThrowableError
Argument 1 passed to Aimeos\MShop\Catalog\Item\Standard::setTarget() must be of the type string, null given, called in D:\Development\htdocs\aimeos20\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Catalog\Item\Standard.php on line 432
btw, in the installation readme it says to run
php artisan aimeos:cache
but that artisan command doesn't exists (any more?) and throws an error
Re: No catalog node
Post by aimeos » 08 Feb 2020, 08:57
2020.01 is a beta release for testing only. Please use the 2019.10 LTS release instead if you want to try Aimeos.
Also, you have to add the demo data to get a working frontend out of the box.
frezno
Re: No catalog node
Post by frezno » 08 Feb 2020, 09:31
well, that's what i did - i tested it and that's what i came up with - result is just FYI
On the other hand i simply followed the instructions on the readme
Shop package only
and the composer command installs the 2020.01
imho it might make sense either to mention that that's a not working Beta or make install the 2019.10 instead of 2020-01
Re: No catalog node
Post by aimeos » 08 Feb 2020, 10:26
Good hint and thanks for mentioning! We've changed that line in the docs.
