modify item
JuanMRuiz
modify item
Post by JuanMRuiz » 28 Apr 2020, 21:33
Hello a query and I have obtained an item
$ manager = \ Aimeos \ MShop :: create ($ context, 'customer');
$ item = $ manager-> getItem ($ id);
What I want is to be able to modify some data of the item and save it. Slaudos and thanks
Re: modify item
Post by aimeos » 29 Apr 2020, 17:03
Here you can find the methods for modifying the item:
https://github.com/aimeos/aimeos-core/b ... /Iface.php
Afterwards, save the item using:
$manager->saveItem( $item );
