Category menu - opened as stanadard
bouuman
Post by bouuman » 24 May 2020, 09:20
How can i configure the Categorys opened as standard, so the users dont have to click the text "Category" to make them visible as standard? Is that possible? :
Re: Category menu - opened as stanadard
Post by aimeos » 25 May 2020, 17:20
Yes, set the number of category levels you want to display using this configuration: https://aimeos.org/docs/Configuration/C ... els-always
bouuman
Post by bouuman » 25 May 2020, 19:16
aimeos wrote: 25 May 2020, 17:20 Yes, set the number of category levels you want to display using this configuration: https://aimeos.org/docs/Configuration/C ... els-always
i used this in my template setup :
plugin.tx_aimeos.settings.client.html.catalog.filter.tree.levels-always = 1
but nothing happens, or how it have to be configured, can you make a example?
Post by aimeos » 27 May 2020, 08:30
In TYPO3, the TS settings are overwritten by the Flexform settings, so you have to go to the plugin configuration of the catalog filter plugin and add the value (2 or 3, depending on the levels of your tree) to the "levels always" field in the flexform.
bouuman
Post by bouuman » 27 May 2020, 17:38
aimeos wrote: 27 May 2020, 08:30 In TYPO3, the TS settings are overwritten by the Flexform settings, so you have to go to the plugin configuration of the catalog filter plugin and add the value (2 or 3, depending on the levels of your tree) to the "levels always" field in the flexform.
whatever i enter in the "Always display these category levels" field, 0, 1, 2 or 3, nothing happens... i tryed clear cache / delete typo temp folder but Categorys still closed. Or i misunderstood how to configure it?
Catalog filter.png (61.9 KiB) Viewed 19365 times
Post by aimeos » 29 May 2020, 20:26
We are still investigating the issue, please stay tuned :-)
Post by aimeos » 02 Jun 2020, 21:35
Here's a new pre-release which fixes the level-always configuration option:
https://aimeos.org/fileadmin/download/a ... 3-pre5.zip
bouuman
Post by bouuman » 03 Jun 2020, 16:05
aimeos wrote: 02 Jun 2020, 21:35 Here's a new pre-release which fixes the level-always configuration option:
installed the new release
didnt worked for me, what have i exactly to do, tryed 1, 2 and 3 but nothing (cleared cache / temp)
Post by aimeos » 03 Jun 2020, 17:10
We've added this: https://github.com/aimeos/ai-client-htm ... 327fd4222f
Then, this method will add the expression for limiting the categories to the configured level:
https://github.com/aimeos/ai-controller ... #L215-L285
Can you please see what happens in your case in the method and if the expression is added:
https://github.com/aimeos/ai-controller ... d.php#L254
bouuman
Post by bouuman » 03 Jun 2020, 18:44
aimeos wrote: 03 Jun 2020, 17:10 We've added this: https://github.com/aimeos/ai-client-htm ... 327fd4222f
1.) this file was OK:
httpdocs / typo3conf / ext / aimeos / Resources / Private / Extensions / ai-controller-frontend / controller / frontend / src / Controller / Frontend / Catalog / Standard.php
2.) This part didnt changed after update:
i adjusted it to your change:
$view->treeCatalogPath = $catItems;
$view->treeCatalogTree = $cntl->visible( $catItems->keys()->toArray() ?: [$startid] )->getTree();
$view->treeFilterParams = $this->getClientParams( $view->param(), ['f'] );
... cleared cache / temp folder... still nothing, i have the feeling that the configuration "Always display these category levels " is dead somehow.
3.) sorry i have no idea how to debug it and check if there is something wrong.
