catalog-suggest restrict search
Bernhard
Post by Bernhard » 03 Jun 2020, 14:01
Hi all,
how can I limit the search-suggests to the search in the product name (or product name, short and long?)
Background is that a lot of the products in our shop contain certain components (e.g. distilled water), so that when searching for "distilled water" almost all products appear.
Another variant would be to sort the results in the product names at the top of the list.
Thanks in advance
Bernhard
Re: catalog-suggest restrict search
Post by aimeos » 03 Jun 2020, 17:13
If you really want to change the indexing process, you need to overwrite this method:
https://github.com/aimeos/aimeos-core/b ... #L684-L734
Bernhard
Post by Bernhard » 05 Jun 2020, 07:17
thanks for the advice.
I think it would be nice to have a possibility to configure the type-ahead suggestion list (as well as the search plugin?) to search and display only the product names from the index.
Regards Bernhard
