Remove items from cart if quantity is zero
cnoelker
Post by cnoelker » 26 Jun 2020, 12:35
is there a way to configure aimeos so that the user may enter zero (0) as a quantity? Then, the action should be the same as if the user clicked on the Minus button, i.e. delete the item from the cart.
Currently, this results in an error message that no price could be determined for quantity 0.
Claudia
Re: Remove items from cart if quantity is zero
Post by aimeos » 03 Jul 2020, 14:01
Best option would be to remove the product here from the basket if the quantity is 0:
https://github.com/aimeos/ai-controller ... d.php#L286
If you create a PR, we will be happy to merge it :-)
