aimeos and vuejs ( axios.get )
mahmoud
Post by mahmoud » 02 Jul 2020, 20:05
I use laravel and vuejs I want to display the product attributes using the following function:
<script>
    export default {
        data () {
            return {
                products: {}
            created () {
                this.getProducts (); },
            methods: {
                getProducts () {
                   axios.get ('/ api / jsonapi / product')
                    .then (response => this.products = response.data)
                    .catch (err => console.log (err));
</script>
and display the data in the component by the for ball like this:
<tr v-for = "(product, index) in products.data"
                        : key = "index">
                        <th scope = "row"> {{index}} </th>
                        <td> {{product.id}} </td>
                       <td>  {{product.attributes.product.id. }}</td>
                        <td> </td>
                          <td> {{product ['attributes'] [product ['id']]}} </td>
                         </tr>
but the last two lines ( {{product.attributes.product.id. }} ... ) are not correct.
Thank you
mahmoud
Re: aimeos and vuejs ( axios.get )
Post by mahmoud » 03 Jul 2020, 00:55
the secret line is :
 {{ product.attributes["product.url"]}}
It works very well !!! , but now I want to display pagination but I don't know how, there is no page variable to do like this:
</div>  <div class="card-footer d-flex justify-content-center">
                    <pagination :data="products" @pagination-change-page="getProducts"></pagination>
                    </div>
this for offset:
 axios.get('/api/jsonapi/product?page[offset]=0')
Thank you
Post by aimeos » 03 Jul 2020, 11:34
The links section of the response contains the first, prev, next and last links which you can use to build the pagination.
