[Solved] How to properly override catalog list template?
rowild
Post by rowild » 12 Oct 2020, 21:59
Hi!
I cannot get the template override feature working.
In my extension I use an "aimeos__catalog-list" plugin, which has exactly 1 category assigned and should display all text and media elements of the that very category (only first level). I want to assign that plugin a new template called "body-startpage.php", which lies in the same folder as "body-standard.php":
`public/typo3conf/ext/theme/Resources/Private/Extensions/aimeos/client/html/templates/catalog/lists/body-startpage.php`
In the plugin's Typoscript configuration field I entered this line:
`client.html.catalog.lists.items.standard.template-body = catalog.lists.body-startpage`
But that does not seem to be correct, because the frontend displays the error message "A non -recoverable error occured".
(The contents of the category are displayed anyway, but it seems the system falls back to the standard template.)
Any idea what I am doing wrong?
Thank you!
rowild
Re: How to properly override catalog list template?
Post by rowild » 13 Oct 2020, 11:27
Anybody?
Post by aimeos » 13 Oct 2020, 16:45
Use:
client.html.catalog.lists.items.standard.template-body = catalog/lists/body-startpage
rowild
Post by rowild » 13 Oct 2020, 19:55
Thank you very much! :D
The tricky part is to stick to dot notation only on the left-hand side of the equal sign, but keep slashes on the right-hand side!
