jquery-ui removed in 2020?
pixelplumber
Post by pixelplumber » 16 Oct 2020, 06:15
Hi, just testing an upgrade of TYPO3 to 10.x with aimeos 2020 to see what will need to be migrated with our custom theme.
Got a typo3 asset exception about missing jquery-ui-custom.min.js. Looking at the commit history I can see that commit [eb6e150] a few days ago on the 14th removed that file.
It looks to still be referenced in /Configuration/TypoScript/setup.txt file though causing an exception.
I commented out that line in setup.txt, but should jquery-ui be removed or not?
Thanks.
Re: jquery-ui removed in 2020?
Post by aimeos » 16 Oct 2020, 07:57
Thank you for your hint!
jquery-ui has been moved to the aimeos.js file and in the 2020.10.x-dev branch, the reference is removed now.
