[Solved] Re-define template in $this->partials($this->config() ... possible?
rowild
Post by rowild » 16 Oct 2020, 08:13
I would like to override the filter tree components. In a first step, the templates are overridden in the Typoscript Configuration field of the "aimeos__catalog-tree" extension:
client.html.catalog.filter.tree.standard.template-body = catalog/filter/tree-body-startpage
client.html.catalog.filter.partials.tree = catalog/filter/tree-partial-startpage
That works fine. Now I would like to use a different template for all categories of level 1. I thought I could do that by manipulating this art of the code:
 // tree-partial-startpage.php, around line 125ff
<?php if( count( $item->getChildren() ) > 0 ) : ?>
	<?= $this->partial(
		$this->config(
			'client/html/catalog/filter/partials/tree',
			'catalog/filter/tree-partial-startpage-categories' ),  // <== use new partial in levels > 0?
			'nodes' => $item->getChildren(),
			'path' => $this->get( 'path', map() ),
			'level' => $this->get( 'level', 0 ) + 1,
			'params' => $this->get( 'params', [] )
<?php endif; ?>
pointing to a different template within the
`$this->config($this->partial-> ...
section.
Unfortunately, this does not work.
What would be the proper way to do that? If it is possible at all?
Thank you!
TYPO3 9.5.22, aimeos 2020.7.5, php 7.3.23
JonasEberleDmind
Re: Re-define template in $this->partials($this->config() ... possible?
Post by JonasEberleDmind » 16 Oct 2020, 11:46
What exactly does not work? Is the template not loaded?
rowild
Post by rowild » 16 Oct 2020, 12:02
The same template that is defined in the Typoscript Configuration is displayed again. Not the new one that is refered to in the loop.
rowild
Post by rowild » 16 Oct 2020, 12:32
I have troubles understanding the "$this->partials($this->config" logic.
E.g., when I take this snippet that is responsible for displaying the media:
. $this->partial(
	$this->config(
		'client/html/common/partials/media',
		'common/partials/media-standard'
	array( 'item' => $mediaItem, 'boxAttributes' => array( 'class' => 'media-item' ) )
and I assign it a non existing template:
'common/partials/this-template-does-not-exist'
then an error is thrown in the FE (one of those "An unrecovereable error...").
But when I assign a wrong template in the loop section of the tree filter:
	<?= $this->partial(
		$this->config(
			'catalog/filter/template-does-not-exist' ),  // <== wrong template here
nothing spectacular happens, no error, everything is displayed using the template assigned via TS.
Why does the second scenario not throw an error?
Post by aimeos » 16 Oct 2020, 15:39
You've configured "client/html/catalog/filter/partials/tree" elsewhere so the default value in the second parameter isn't used.
rowild
Post by rowild » 20 Oct 2020, 16:57
I can confirm that once a template override is done in TypoScript, a "default" is defined. And that means that the respective php functions won't reassign a new template anymore.
In my case, to stay flexible, it seems to be better to override templates directly in the php `$hits->partial($this->config ...` functions.
