(Solved) Symfony\Component\Routing\Exception\InvalidParameterException
Rocco
Post by Rocco » 27 Oct 2020, 08:16
Dear Aimeos Team
I have integrated the aimeos shop into my existing website
TYPO3 10.4.9 in composer mode
Aimeos 20.10.1
PHP Version 7.2.24
Operating system: Unix on Mac Os X
The update script has no error and the aimeos dashboard is accessible with the contents.
On the fe output:
I have the (1/1) Symfony\Component\Routing\Exception\InvalidParameterException
Parameter "ai__f_sort" for route "ai_0" must match "[^/]++" ("" given) to generate a corresponding URL.
I am sure that I am missing something at the configuration.
Can someone give me a tip, what could be the reason?
Many thanks in advance and best regards
Re: Symfony\Component\Routing\Exception\InvalidParameterException
Post by aimeos » 27 Oct 2020, 09:01
Can you remove the route enhancers from your site configuration?
Seems like one of the rules make problems.
Rocco
Post by Rocco » 27 Oct 2020, 09:56
Many thanks for your reply
I had this as routeEnhancers
routeEnhancers:
Aimeos:
type: Extbase
namespace: ai
defaultController: 'Catalog::list'
routes:
- { routePath: '/pin/{pin_action}/{pin_id}/{d_name}', _controller: 'Catalog::detail' }
- { routePath: '/history/{his_action}/{his_id}', _controller: 'Account::history' }
- { routePath: '/watch/{wat_action}/{wat_id}', _controller: 'Account::watch' }
- { routePath: '/watch/{wat_action}', _controller: 'Account::watch' }
- { routePath: '/fav/{fav_action}/{fav_id}', _controller: 'Account::favorite' }
- { routePath: '/fav/{fav_action}', _controller: 'Account::favorite' }
- { routePath: '/c/{f_name}~{f_catid}', _controller: 'Catalog::list' }
- { routePath: '/l/{f_sort}', _controller: 'Catalog::list' }
- { routePath: '/b/{b_action}', _controller: 'Basket::index' }
- { routePath: '/co/{c_step}', _controller: 'Checkout::index' }
- { routePath: '/p/{d_name}/{d_prodid}/{d_pos}', _controller: 'Catalog::detail' }
- { routePath: '/d/{d_name}/{d_pos}', _controller: 'Catalog::detail' }
defaults:
b_action: ''
c_step: ''
f_sort: ''
d_pos: ''
Without them i have the following error
(1/1) #1530169746 TYPO3\CMS\Core\Resource\Exception\InvalidFileNameException
Empty file name given
in /Users/roccohofer/Sites/kristall10/public/typo3/sysext/frontend/Classes/Resource/FilePathSanitizer.php line 82
public function sanitize(string $originalFileName): string
$file = trim($originalFileName);
if (empty($file)) {
throw new InvalidFileNameException('Empty file name given', 1530169746);
if (strpos($file, '../') !== false) {
throw new InvalidPathException('File path "' . $file . '" contains illegal string "../"', 1530169814);
Rocco
Post by Rocco » 27 Oct 2020, 11:03
It seems to be a problem width the installed SASS compiler for TYPO3 "ws_scss".
Have you a idea, how to solve ist?
Rocco
Post by Rocco » 29 Oct 2020, 11:28
It works now.
The problem was effectively the extension "ws_scss".
I built the Sass compiling into my extension and the shop works as intended.
Many thanks for your support and this wonderful tool.
