Media not showing in backend
parmonov98
Post by parmonov98 » 16 Oct 2020, 04:33
aimeos wrote: 26 Aug 2020, 08:09 You are right, in TYPO3 the prefix from "resource/fs/baseurl" isn't used. We've fixed that and you can install the latest commit using:
composer req aimeos/ai-admin-jqadm:2020.07.x-dev
2020.10-dev using.
the same problem in frontend too. but after changing APP_URL in .env file to http://127.0.0.1:8000 it started showing product imgs in front-end but in the backend. The change doesn't affect. What can I do?
https://i.imgur.com/OnR7owA.png
Re: Media not showing in backend
Post by aimeos » 16 Oct 2020, 15:56
Did you set the following in your .env file (no slash at the end)?
APP_URL=http://127.0.01:8000
Changing the APP_URL constant and adding the port is required when you use the internal PHP web server (see https://github.com/aimeos/aimeos-laravel#setup after the Blade template code).
If it's correct, please check if the file is stored in the ./public/preview/8/f/ directory at all.
harshithvemula
Post by harshithvemula » 17 Oct 2020, 09:12
I am using laravel and facing the same issue. Media is not getting displayed in backend. I have inspected elements and found an extra / in the url of image.
http://127.0.0.1:8000//preview/e/d/ed5b3df5_2066981171.jpg
My App url is APP_URL=http://127.0.0.1:8000(No slash at end)
Post by aimeos » 17 Oct 2020, 09:17
Does this link work and displays the image (URL is without double slashes):
http://127.0.0.1:8000/preview/e/d/ed5b3df5_2066981171.jpg
If yes, can you please execute:
php artisan aimeos:clear
Maybe the output is cached.
harshithvemula
Post by harshithvemula » 17 Oct 2020, 09:27
yes this url is displaying the image
and even i have executed this command now
and refreshed the page but the images are not displaying.
Post by aimeos » 17 Oct 2020, 09:29
Is the URL of the image still
harshithvemula
Post by harshithvemula » 17 Oct 2020, 09:33
yes the url is still same. Just now i copied it from inspect elements.
http://127.0.0.1:8000//preview/6/7/678bbcf5_2079903277.jpg
my aimeos version is "aimeos/aimeos-laravel": "~2020.10.1",
Post by aimeos » 17 Oct 2020, 09:35
Can you do a quick test what this PHP code in a Laravel controller returns?
config( 'app.url' )
harshithvemula
Post by harshithvemula » 17 Oct 2020, 09:51
I placed the code in the return view of a controller and i got this message when i opened the view.
return Response::view(config( 'app.url' ) );
output-
View [http:..127.0.0.1:8000] not found.
Post by aimeos » 17 Oct 2020, 10:18
Is there a slash in the mshop_media.preview records? Can you please post a screenshot?
