PostgreSQL: product search with multiple terms
Hi, using aimeos 2020.10 and PostgreSQL 9.5 DB:
Product search (text search) with a single term like eg. "term1" works fine.
But searches with multiple terms separted by space eg. "term1 term2" cause an error:
"A non-recoverable error occured"
and in log
SQLSTATE[42601]: Syntax error: 7 ERROR: syntax error in tsquery: "term1 term2"
Using + instead of space eg. "term1+term2" provides correct results.
Wrong setting / config or are multiple search term not supported by aimeos for PostgreSQL ?
Thanks!
and in log
Thanks!
Re: PostgreSQL: product search with multiple terms
The problem may be located here:
https://github.com/aimeos/aimeos-core/b ... L.php#L102
Does it work when you change to
' & 'Code: Select all
' +'Professional support and custom implementation are available at Aimeos.com
Unfortunately it doesn't solved the issue.
- while entering "term1 term2" (without +) only search suggestions for term1 are presented (term2 ignored). After clicking "enter" the error message is shown.
- while entering "term1+term2" (with +), correct search suggestions (only results containing term1 and term2) are presented. After clicking "enter" the correct results are displayed
We've fixed the problem in this commit:
https://github.com/aimeos/aimeos-core/c ... def787b6be
You can update your installation using:
composer up aimeos/aimeos-core:2020.10.x-devProfessional support and custom implementation are available at Aimeos.com
The provided code did not solve it at first run. But after replacing:
with the original line:
its working fine now !
Here the complete code of PgSQL.php:
Thank you
$params[1] = join( ' | ', $strings ) . ' | "' . join( ' <-> ', explode( ' ', $search ) ) . '"';Code: Select all
$params[1] = '\'' . join( ' & ', $strings ) . '\''; Here the complete code of PgSQL.php:
<?php
* @license LGPLv3, https://opensource.org/licenses/LGPL-3.0
* @copyright Aimeos (aimeos.org), 2016-2020
* @package MShop
* @subpackage Index
namespace Aimeos\MShop\Index\Manager\Text;
* PostgreSQL based index text for searching in product tables.
* @package MShop
* @subpackage Index
class PgSQL
extends \Aimeos\MShop\Index\Manager\Text\Standard
private $searchConfig = array(
'index.text:relevance' => array(
'code' => 'index.text:relevance()',
//'internalcode' => ':site AND mindte."langid" = $1 AND CAST( to_tsvector(\'english\', mindte."content") @@ to_tsquery( $2 ) AS integer )',
'internalcode' => ':site AND mindte."langid" = $1 AND CAST( to_tsvector(mindte."content") @@ to_tsquery( $2 ) AS integer )',
'label' => 'Product texts, parameter(<language ID>,<search term>)',
'type' => 'float',
'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_INT,
'public' => false,
'sort:index.text:relevance' => array(
'code' => 'sort:index.text:relevance()',
//'internalcode' => 'ts_rank(to_tsvector(\'english\', mindte."content"), to_tsquery( $2 ))',
'internalcode' => 'ts_rank(to_tsvector(mindte."content"), to_tsquery( $2 ))',
'label' => 'Product text sorting, parameter(<language ID>,<search term>)',
'type' => 'float',
'public' => false,
* Initializes the object
* @param \Aimeos\MShop\Context\Item\Iface $context Context object
public function __construct( \Aimeos\MShop\Context\Item\Iface $context )
parent::__construct( $context );
$level = \Aimeos\MShop\Locale\Manager\Base::SITE_ALL;
$level = $context->getConfig()->get( 'mshop/index/manager/sitemode', $level );
$name = 'index.text:relevance';
$expr = $this->getSiteString( 'mindte."siteid"', $level );
$this->searchConfig[$name]['internalcode'] = str_replace( ':site', $expr, $this->searchConfig[$name]['internalcode'] );
//$this->searchConfig[$name]['function'] = $this->getFunctionRelevance();
$this->searchConfig[$name]['function'] = $this->searchConfig['sort:' . $name]['function'] = $this->getFunctionRelevance();
* Returns a list of objects describing the available criterias for searching.
* @param bool $withsub Return also attributes of sub-managers if true
* @return \Aimeos\MW\Criteria\Attribute\Iface[] List of search attriubte items
public function getSearchAttributes( bool $withsub = true ) : array
$list = parent::getSearchAttributes( $withsub );
foreach( $this->searchConfig as $key => $fields ) {
$list[$key] = new \Aimeos\MW\Criteria\Attribute\Standard( $fields );
return $list;
* Returns the search function for searching by relevance
* @return \Closure Relevance search function
protected function getFunctionRelevance()
return function( $source, array $params ) {
if( isset( $params[1] ) )
$strings = [];
$regex = '/(\&|\||\!|\-|\+|\>|\<|\(|\)|\~|\*|\:|\"|\'|\@|\\| )+/';
$search = trim( mb_strtolower( preg_replace( $regex, ' ', $params[1] ) ), "' \t\n\r\0\x0B" );
foreach( explode( ' ', $search ) as $part )
if( strlen( $part ) > 2 ) {
$strings[] = $part . ':*';
//$params[1] = join( ' | ', $strings ) . ' | "' . join( ' <-> ', explode( ' ', $search ) ) . '"';
return $params;
}Re: PostgreSQL: product search with multiple terms
There was another commit yesterday adding the apostrophes after the mentioned commit:
https://github.com/aimeos/aimeos-core/c ... a2ee494188
If you update to the latest commit, it should work without modifications and rank phrase queries higher than prefix terms.
thank you! - tested the newer code; it combines search terms with logical "OR".
For our purpose an "AND"-combination would be better. So we plan to use the "older" code with ' & '
Do you plan any configurations (eg. in shop.php) how search terms are combined or are settings already available yet?
eg. available product names:
- Product 1 term1 abc
- Product 2 term2 def
- Product 3 term1 term2 ghi
- Product 4 term3 jkl
search "term1 term2" with:
result:
but search "term1 term2" with:
result:
$params[1] = '\'' . join( ' & ', $strings ) . '\'';- Product 3 term1 term2 ghi
$params[1] = '\'' . join( ' | ', $strings ) . ' | "' . join( ' <-> ', explode( ' ', $search ) ) . '"\'';- Product 1 term1 abc
Does it return the results in that order? Would expectcolumbo wrote: 03 Jan 2021, 13:38 eg. available product names:
search "term1 term2" with:result:Code: Select all
due to a higher ranking of the phrase compared to the single terms. In e-commerce its usually better to return more results instead of nothing but the better matching products must be displayed first.
Unfortunately not.
Phrases or products wiht both terms (term1 and term2) in the product name are not higher ranked / listed as first result
We've made some tests with the Aimeos unittest data and we get the ranking we expect.
Terms:
Generated SQL query:
Result:
Can you see what query is generated in your installation and what the result set is?
Terms:
cafe noire discCode: Select all
SELECT mpro."id", mpro.label, MIN(ts_rank(to_tsvector(mindte."content"), to_tsquery( 'cafe:* | noire:* | disc:* | "cafe <-> noire <-> disc"' ))) AS "s0"
FROM "mshop_product" AS mpro
LEFT JOIN "mshop_index_text" AS mindte ON mindte."prodid" = mpro."id"
WHERE ( ( mpro."siteid" = '482.' OR mpro."siteid" = '' ) AND ( mindte."siteid" = '482.' OR mindte."siteid" = '' ) AND mindte."langid" = 'de' AND CAST( to_tsvector(mindte."content") @@ to_tsquery( 'cafe:* | noire:* | disc:* | "cafe <-> noire <-> disc"' ) AS integer ) > 0 )
GROUP BY mpro."id"
ORDER BY "s0" DESC
OFFSET 0 ROWS FETCH NEXT 100 ROWS ONLY;
id | label | s0
4933 | Cafe Noire Expresso | 0.080494
4932 | Cafe Noire Cappuccino | 0.0576968
4910 | MNOP/16 discs | 0.0202642
4911 | QRST/16 discs | 0.0202642
