Selection product not importing properly in CSV Import
zaheer
Post by zaheer » 28 Jan 2021, 06:32
I am using Sample CSV file for import.
There are no errors on import and the products are added to tables.
But the variants are not being added. Here are the screen shots.
My shop.php is :
	'controller' => [
		'jobs' => [
			'product' => [
				'import' => [
					'csv' => [
						'location' => public_path() . '/tmp',
						'skip-lines' => 1,
						'container' =>[
							'type' => 'Directory',
							'content' => 'CSV',
						'mapping' => [
                            'item' => [
                                1 => 'product.label', // UTF-8 encoded text, also used as product name
                                2 => 'product.type', // type of the product, e.g. "default" or "selection"
                                3 => 'product.status', // enabled (1) or disabled (0)
							'text' => [
								4 => 'text.type',
								5 => 'text.content',
								6 => 'text.type',
								7 => 'text.content',
							'media' => [
								8 => 'media.url',
							'price' => [
								9 => 'price.currencyid',
								10 => 'price.quantity',
								11 => 'price.value',
								12 => 'price.taxrate',
							'attribute' => [
								13 => 'attribute.code',
								14 => 'attribute.type',
							'product' => [
								15 => 'product.code',
								16 => 'product.lists.type',
							'property' => [
								17 => 'product.property.value',
								18 => 'product.property.type',
                            'catalog' => [
                                19 => 'catalog.code', // e.g. Unique category code
                                20 => 'catalog.lists.type', // e.g. "promotion" for top seller products
CSV file is attached.
What I am missing here, please help.
products-import-example.zip
(528 Bytes) Downloaded 389 times
Re: Selection product not importing properly in CSV Import
Post by aimeos » 29 Jan 2021, 09:43
Did you create the attributes first? The product CSV import doesn't do that automatically if you forgot to add them before.
zaheer
Post by zaheer » 30 Jan 2021, 07:22
The documentation says that attributes are automatically created.
"Nevertheless, if an attribute doesn't exist, it will be created automatically."
"size" attribute was already added.
"S/M" & "M/L" no. But I also tried adding them. Still same result.
I can see the attributes in list if I try to manually add them.
Post by aimeos » 30 Jan 2021, 10:36
OK, then it's the missing product.lists.type column for each attribute type/value pair column with the value "variant" so the attributes are added as variant attributes instead of regular attributes. Instead of:
attribute.type;attribute.code;attribute.type;attribute.code
size;M/L;color;blue
Use:
product.lists.type;attribute.type;attribute.code;product.lists.type;attribute.type;attribute.code
variant;size;M/L;variant;color;blue
zaheer
Post by zaheer » 01 Feb 2021, 06:48
Thanks alot.
Yes, this fixed the issue.
