Products only on specifiy days of the week
tobiasschnier
Post by tobiasschnier » 04 Feb 2021, 13:26
I'm pretty new to aimeos and so far I haven't found what I needed in the documentation. First of all my setup:
Laravel: 6.20.15
PHP: 7.4.7
Aimeos: 2020.10
Mac
I want to display certain products only on certain days. For example: Article 1 should only be available on Mondays and Tuesdays... Is that possible with aimeos, without having to set it to disabled manually?
Thanks for the help!
Re: Products only on specifiy days of the week
Post by aimeos » 06 Feb 2021, 16:36
Not on weekdays. You can limit products to a certain timeframe using the start date and the end date that's available for each product instead:
tobiasschnier
Post by tobiasschnier » 08 Feb 2021, 09:58
Thanks for your answer =)
