Wrong categories in multimandate shop
I have a multi mandate installation of Aimeos. There are 4 sites, and 3 of them are running well. I've got a problem with the latest site when trying to provide the correct category in Backend in plugin "Catalog filter" (also in "Catalog list"), I provided the correct sitename in Typoscript and in PageTS, though.
Static Aimeos template is included.
TS: plugin.tx_aimeos.settings.mshop.locale.site = beachboysbern
PageTS: tx_aimeos.mshop.locale.site = beachboysbern
What could fix the problem?
Thanks for help,
Kurt
TYPO3: 9.5
PHP: 7.3
Aimeos: 20.10.6
Thanks for help,
Kurt
TYPO3: 9.5
PHP: 7.3
Aimeos: 20.10.6
- not-correct.png (9.17 KiB) Viewed 5119 times
Re: Wrong categories in multimandate shop
The PageTS setting is relevant for the shown categories. Check if there are no invisible characters in the input field by clearing the field and typing the string by hand.
I checked the setting several times and compared it with a working example, but it didn't help...
Other suggestions?
Other suggestions?
I'm very sorry!!! The problem is solved. There was a line in shop-subpage which overwrote the given setting!
