Error when deleting product
MikaelNazarenko
Expert
Post by MikaelNazarenko » 11 Apr 2021, 20:53
Hi, community, I am getting error when I try to delete product..
Array to string conversion in file: vendor/laravel/framework/src/Illuminate/Routing/RouteUrlGenerator.php:220
Here is the error details: https://flareapp.io/share/w5BGyadm#F59
Here are components versions:
aimeos/ai-admin-jqadm                     dev-master 636ffbb Aimeos Vue.js+Bootstrap admin interface
aimeos/ai-admin-jsonadm                   dev-master 4066c11 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                     dev-master b9f1e5d Aimeos ai-client-html extension
aimeos/ai-client-jsonapi                  dev-master 45ba16b Aimeos JSON API extension
aimeos/ai-cms-grapesjs                    dev-master e0ba779 Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend             dev-master d659352 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs                 dev-master dd4c56b Aimeos ai-controller-jobs extension
aimeos/ai-gettext                         dev-master 2c12fb9 Aimeos Gettext extension
aimeos/ai-laravel                         dev-master 82ed2ab Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                     dev-master ceb8275 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                        dev-master 6ae50ca Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                     dev-master b771b5e Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
aimeos/map                                2.1.0              Easy and elegant handling of PHP arrays as array-like map objects similar to jQuery and Laravel Collections
Please help me to figure out the problem,
Thanks!
Re: Error when deleting product
Post by aimeos » 13 Apr 2021, 13:48
First, make sure you use the lastest version by running:
composer up
As we've already released aimeos/aimeos-laravel:~2021.04, you should use that version now if you don't want to develop something for the core.
Then: What is the line in templates/product/list-standard.php:585?
