Syntax Error
mahmoud
Syntax Error
Post by mahmoud » 20 Apr 2021, 11:46
In the file:
vendor\aimeos\aimeos-core\lib\mshoplib\setup\StockMigrateProductId.php
This syntax is not correct for POSTGRESQL:
'unq_mssto_sid_pcode_ty' => 'DROP INDEX "unq_mssto_sid_pcode_ty" ON "mshop_stock"',
the correct syntax like :
Tank you
Re: Syntax Error
Post by aimeos » 21 Apr 2021, 06:27
Thank you for pointing out. Can you please create an issue in the https://github.com/aimeos/aimeos-core Github repository?
Re: Syntax Error
Post by aimeos » 24 Apr 2021, 08:44
