Configuration of the partial method
JackDarkWeb
Post by JackDarkWeb » 01 Jun 2021, 17:12
<?= $this->partial($this->config('client/html/common/partials/products', 'common/partials/products-standard' ),
'products' => $products
If I understand this script correctly, it allows to get the variable products in the file products-standard.php.
Now I want to get this same variable products in the file body-standard.php in the folder catalog/home.
I did this but the variable data is empty
<?= $this->partial($this->config('client/html/catalog/home/body', 'catalog/home/body-standard' ),
How else can I do it?
Please help me!
Re: Configuration of the partial method
Post by aimeos » 03 Jun 2021, 08:49
The product in the catalog/home component are already rendered here:
https://github.com/aimeos/ai-client-htm ... hp#L89-L93
If you want to show the variant articles of selection products too, just add this configuration:
https://aimeos.org/docs/2021.x/config/c ... basket-add
Be care full and assign only a few products to the Home category. Otherwise, your home page will be very slow when using this setting!
JackDarkWeb
Post by JackDarkWeb » 04 Jun 2021, 08:43
thank you for your answer.
I notice that on the home page it is the products in promotion that are display.
Now if want to display all the latest products without exception
Post by aimeos » 05 Jun 2021, 06:24
In that case, you have to extend from the existing catalog/home component and overwrite the addData() method with your own implemenation:
https://github.com/aimeos/ai-client-htm ... #L410-L515
