Problem After update on admin panel
after updating the project from 2021.04 to 2021.07 the extension loaded fine. But the admin panel has crashed and I can't navigate between tabs.
Loading animations don't finish
the paths seem fine but the scripts could be the problem?
Thanks a lot
Thanks a lot
- Captura.PNG (48.71 KiB) Viewed 7561 times
Re: Problem After update on admin panel
Please open your browser console and make a screenshot of the JS error if there's any.
hi,
I could solve the problem deleting the admin views in the shop folder. Then proyect takes the predefined and now it works correctly.
Thank you very much anyway!
