How can i remove minimum character validation in catalog search?
vishal_thakur
Re: How can i remove minimum character validation in catalog search?
In custom JS, set:
AimeosCatalogFilter.MIN_INPUT_LEN = 1;Professional support and custom implementation are available at Aimeos.com
vishal_thakur
it's only works for frontend means it's only remove min input length validation from frontendaimeos wrote: 04 Sep 2021, 06:56 In custom JS, set:Code: Select all
we have some products which have only 2 digit SKU code . like 0-99 https://prnt.sc/1re08uj
but search doesn't work with 1 or 2 digit : https://prnt.sc/1re0fy7
can you please check this ?
The MySQL full text search has a minimum character length too. Here you can find how to change that:
https://aimeos.org/docs/latest/infrastr ... hort-words
vishal_thakur
For Search for short words https://aimeos.org/docs/2021.x/infrastr ... hort-wordsaimeos wrote: 07 Sep 2021, 08:23 The MySQL full text search has a minimum character length too. Here you can find how to change that:
Where my.cnf configuration file is located?
what is exact path for .cnf file?
