Problem with Aimeos - Catalog simple search list
RoMkO
Post by RoMkO » 21 Oct 2014, 19:09
Tell me please how can I remove this???
Re: Problem with Aimeos - Catalog simple search list
Post by aimeos » 23 Oct 2014, 07:28
Seems like you have placed the catalog list simple plugin in the right column of your page. This produces a JSON output that is required for the suggestions displayed while typing in the search box.
Maybe renaming the plugin would make this more clear.
RoMkO
Post by RoMkO » 23 Oct 2014, 22:40
Thank you very much !!!!!!
