sell product weight based
GülsümAkça
Post by GülsümAkça » 04 Nov 2021, 10:16
I want to sell products with weight based(100 gram, 200 gram etc.). How can I enter the price for 100 grams in the admin panel. I will use the quantitiy option for weight.
Or is there a solution other than creating variant for selling products weight based?
Thank you for your help
Re: sell product weight based
Post by aimeos » 05 Nov 2021, 07:39
If you have fixed packages, use variants for 100g, 200g, 500g, 1kg and so on.
If your customers should be able to buy any multiple of 100g, than you should set the "Quantity scale" in the basic product panel to 100 (if everything is in gram) or 0.1 (if everything is in kg) and set the "Miniumn quantity" in the price panel to the same value. Then, add more prices with different price values and multiple of 100/0.1
