Select type Product csv import
whatdaro
Post by whatdaro » 25 Nov 2021, 21:28
Aimeos Ver: 2021.10.2
OS: Linux
database: MariaDB
hi Aimeos team,
When importing products of the Select type, the example given to import the Select product and a variant is only for a single variant.
Could you please let me know what is the format or syntax to import a Select product with multiple variant, thanks.
Re: Select type Product csv import
Post by aimeos » 26 Nov 2021, 17:55
Just add more lines with variants before the selection product and reference the variant article codes in the selection product like done in the example file:
https://aimeos.org/fileadmin/download/p ... xample.csv
